9 years agoTiming violations - TimeQuest vs. Compile results ?????
I am pretty new to working with TimeQuest and working out timing violation in a design. In our current design we seem to be having some timing issues so I started looking at the TimeQuest analyser. ...
9 years agoYes, it will ease up the timing, but that is only valid if your signals behave in a multi-cycle manner. Eg. Your clock enable is high every other clock cycle - so the signals that use that enable only change once every 2 clocks, so the q output of the register is valid for 2 clock cycles - hence a multi cycle constraint.
If the registers in your design can change every single clock cycle then you do not have a valid multi-cycle constraint. If you specify one, then the design may not work properly on the board.
