Timing models don't match measured delays
I am working with an Agilex 7 I-series device in Quartus Prime Pro 25.3. The device is fully supported by that QPP version and has final timing models.
Since I am working with precise timing, I need to find out the propagation delay from internal clock to output on a pin with as good precision as possible. I am trying to use the Timing Analyzer (TA) to do this. The results do not match my expectations though.
The TA reports paths for five operating conditions for this device: fast/vid1/100C, fast/vid1a/100C, fast/vid1a/0C, slow/vid1b/100C and slow/vid1/100C. My expectation is that one of them corresponds to the shortest propagation delay (used for hold analysis) and one the longest (used for setup analysis) and that my measured delay should therefore fall somewhere between these extremes. It does not.
To test this, I have added two registers to my design, both clocked by the same clock, both toggling at every clock edge. I have instructed Quartus to preserve these and don't merge them. These two registers drive two outputs that I can measure on the board. Then I control the placement of the two registers to get different propagation delay to their pins.
I start out by calibrating the setup. Placing the two registers in the same LAB close to the relevant I/O bank results in very nearly the same path delay to both pins according to the TA. As expected, I also measure a very small difference between the edges (around 100 ps). This shows that there is no significant difference between the board traces or measurement cables.
Then I move one of the registers a bit, 271 LABs in the X direction to be exact. According to the TA, this design should have the following propagation delay differences between the pins for the five operating conditions:
| Fast vid1 100C | 3.134 ns |
| Fast vid1a 100C | 3.138 ns |
| Fast vid1a 0C | 2.795 ns |
| Slow vid1b 100C | 3.028 ns |
| Slow vid1 100C | 3.011 ns |
However, I measure just 2.32 ns. This is lower than even the 0C model, which must be the fastest timing that is used to guarantee hold timing. How can this be?
1 Reply
- sstrell
How are you gathering the numbers in the table from the TA? Are you using data arrival times from whatever is driving these registers and from these registers to the output pins?
I guess it's not clear what design you are using and what is actually driving these registers. Also not clear is your clocking setup. Are you using a PLL that's driving a global clock resource or are you driving the registers directly?
I think more detail on your setup and how you are getting these numbers is needed.
