Sajith_K_Intel
6 years agoTiming driven synthesis option is not found in Quartus 19.4 when Agilex device is selected
When using Agilex device in Quartus 19.4, There is no option to set Timing driven synthesis (in advanced synthesis settings). Hence I am not sure if SDC file will be considered during synthesis. Fro...
- 6 years ago
For Agilex, this feature had been drop
KennyT_altera
6 years agoDo you have a simple design example for Pro and Std? I will make a comparison here and get back to you.
Basically, I do think that synthesis steps should throw syntax error from the SDC since sdc is being taking care of in synthesis when using timing driven synthesis.
Sajith_K_Intel
6 years agoI can provide a sample design of Pro, not Standard as i do not have it.
As you said, timing driven synthesis is by default ON. then why do yo think synthesis will not consider sdc errors?
In the attached example, i do not see any info messages about sdc during synthesis.
