16 years ago
Timing-Driven Synthesis is skipped...
When I run Quartus, I *always* get the message "Timing-Driven Synthesis is skipped because it could not initialize the timing netlist". This happens no matter what settings I use. Any idea what is going on? In case it matters, it is Quartus 9.0 SP2 on a 64-bit Vista machine. Thanks!
Later that day....
Same behavior on 32-bit Vista.
  • PPrib's avatar
    PPrib
    I had (almost?) the same problem in Feb, 2022 (!). I had a COMMENTED OUT LINE immediately following a create_clock. Quartus Prime 20.1.1 Lite insisted on skipping timing-driven synthesis. Removing the comment text fixed the problem.
