11 years agoTiming Constraints for Source Sync Interface with clock coming out of FSM (not PLL)
What I want to do, is to write an SPI Master that drives both the SCLK (ouput) and MOSI (output) from the FSM and also samples MISO (input) in the FSM.
E.g. I clock the FSM process with a 50 MHz clock and generate a 25 MHz SCLK, by toggling SCLK every FSM clock. I would drive MOSI at each rising edge of SCLK and sample MISO at each falling edge of SCLK. The slave interface requires that. My question is, how do I need to constrain the outputs that there is now phase shift between the outputs (SCLK and MOSI). Or can I rely on them "leaving" the FPGA synchronously, since the come out of the same clocked process. All examples for source synchronous interfaces I have seen have the clock coming out of a PLL and not out of an FSM. Or is this not a good approach?2 Replies
Here is a good thread about that: http://www.alteraforum.com/forum/showthread.php?t=31436
Thanks, I didn't find that because I didn't really know what I had to look for.
So what I take from that example is: 1) I have my FSM clock: create_clock -period 20.0 -name clk_in [get_ports {clk_in}] For outputs: 2) I have the output clock that I drive out of the FSM create_generated_clock -invert divide_by 2 -name SCLK -source [get_ports clk_in] [get_ports SCLK] -> divided by 2 because the frequency is divided by 2 in the FSM -> inverted because I drive signals at the rising edge of clk_in, but the slave samples at the falling edge of SCLK 3) Set output delays set_output_delay -clock SCLK -max 5 [get_ports {MOSI}] # setup time of slave, MOSI is FPGA output set_output_delay -clock SCLK -min -5 [get_ports {MOSI}] # hold time of slave, MOSI is FPGA output For inputs: 4) the same derived clock as above -> because the slave drives signals at the rising edge of SCLK, but I sample at the falling edge of SCLK 5) Set input delays set_input_delay -clock SCLK -max 15 [get_ports {MISO}] # Tco of external device, MISO is FPGA input set_input_delay -clock SCLK -min 15 [get_ports {MISO}] # min Tco of external device, MISO is FPGA input
