Timing constraints for external logic that takes input from, and outputs to an FPGA
I was thinking using -from the output and -to the input in the same constraint. Just add up the loop delays (trace + "tco") and use as the value. You don't need to know/use a th or tsu for this.
- TuckerZ2 years ago
Does the program apply the constraint in the way I want it to? Will the timing analyzer "create" a timing path between those two ports that allows the program to use both internal delays during an individual calculation?
For example, Let's say there is
- A generated internal output delay of 2ns
- A total external propagation delay of 3ns
- And a generated internal input delay of 1ns
Would the program be able to recognize that it needs to add the 1ns from the input to the output's max_delay calculation for a total of 6ns?
Thank you for all the information so far,
Tucker Zischka
- sstrell2 years ago
The internal delays would be set up based on the external delay. That's how set_input_delay and set_output_delay work. If you define the external delay with set_max_delay and set_min_delay, it should work the same way.
I added the following constraints.
set_max_delay -from [get_ports output_port] -to [get_ports input_port] 10.368 set_max_delay -from [get_ports output_port] -to [get_ports input_port] 0After rerunning compilation and checking timing, Delays and the Clock Skews for the Registers immediately before the output ports and after the input ports are as follows:
- Clock Delay for the output register is 8.263ns
- The data delay from the output register to the output port is 8.302ns
- The maximum external propagation delay is 10.368ns
- Clock Delay for the input register is 7.773ns
- The data delay from the input port to the input register is 9.817ns
- The clock is running at 120MHz = 8.333ns
The question is, what kind of analysis is being performed on this path now? The ports are currently unconstrained so it is not doing a synchronous analysis.
Doing the math here, there is a negative slack of:
Data Required Time - Data Arrival Time = Slack
(8.333+7.773+9.817) - (8.263+8.302+10.368 ) = -1.01ns
It's not doing that analysis nor reporting the "violation". I expect it to report the violation because the maximum external delay would cause the data to arrive after the latch clock edge.
