11 years ago
Timing constraints for DDR ADC Interface with AD9643
I am working on the DDR Interface with the AD9643 ADC from Analog Devices, but I am not able to catch proper signals! May be someone is familiar with 200MHz DDR Interface, here some informations what I've done so far:
FPGA clk: 200MHz
ADC: AD9643 with 200MHz DDR
DCO of ADC is connected to clk_input of FPGA and its clock is from Hardware PLL directly (200MHz)
Timing Diagram of the AD9643 datasheet
https://www.alteraforum.com/forum/attachment.php?attachmentid=9138
Due to the datasheet of the AD9643, the DCO clock is -90° shifted, so I made the follwing constraints:
create_clock -name {FPGA_CLK200} -period 5.000 -waveform { 0.000 2.500 }
create_clock -name {ADC_DCO} -period 5.000 -waveform { 3.750 6.250 }
I shift the ADC clock to 270° due to the fact that sdc can't handle negative timing constraints.
In the datasheet the TSKEW is marked with min value of 0.4 and max of 1.0ns, due to that I made the following input constraints:
set_input_delay -clock  -min -0.400  -add_delay
set_input_delay -clock  -max -1.000  -add_delay
The ADC-DCO clock is going to an internal PLL and on that clock I read out the DDR data, but its wrong. According to the datasheet I think it is not necessary to ad 90° phaseshift in the FPGA?
Can someone help me with some ideas? Thanks in advance!
1 Reply
    I could catch proper ADC signals with DCO clock on a minimal design, which means that I've made a design only with the needed PLLs and the ADC readout with altddio. After shifting the phase to 90° it worked.
    But I've I go back to my complete design with other parts, it is not working again - I guess the altddio is far away from the pin or another problem. Does anyone have some suggestions to me, for improving this matter?
