tmont3
7 years agoTiming constraints for asynchronous I/O input pin
What is the right way to constraint an FPGA input pin coming from a analog stage whose last stage is a Schmidt trigger, thus converting the signal to "digital domain"? I'm asking this because some t...
tmont3
7 years agoarchitecture test of A_filtering is
signal adderPulses :std_logic_vector (31 downto 0):= x"00000000";
signal outputSignal :std_logic;
begin
A_filtering : process(inSignal, clock, resetb)
begin
if (resetb = '0') then
adderPulses <= x"00000000";
outputSignal <='0';
elsif (clock'event and clock='1') then
if (inSignal ='0') then
if(adderPulses > x"00000000")then
adderPulses <= adderPulses - '1';
end if;
elsif (inSignal ='1') then
if(adderPulses < filter)then
adderPulses <= adderPulses + '1';
end if;
end if;
if (adderPulses =filter)then
outputSignal<='1';
elsif (adderPulses =x"00000000")then
outputSignal<='0';
end if;
end if;
end process A_filtering ;
outSignal <= outputSignal;
end test;Hi Ccong1,
Thanks again for your support. Here is the code I was talking about. Do you think is robust to timing constraint?
I've not copied the entity but, both adderPulses and filter are 32-bit std_logic_vector.
Any council or recommendation would be welcome.
In the meantime i will try implementing a double registered input filtering routine.
talk soon.
