tmont3
7 years agoTiming constraints for asynchronous I/O input pin
What is the right way to constraint an FPGA input pin coming from a analog stage whose last stage is a Schmidt trigger, thus converting the signal to "digital domain"? I'm asking this because some t...
tmont3
7 years agoHi Ccong1,
I appreciate very much your answer, i think that could help me a lot.
With "does not reveal the input signal" i would like to emphasize that, sometimes, while one of the 2 FPGAs w same project and same input signal is able to detect the state change of the input signal (i.e. from 0 to 3.3V) the other is not.
I've check in my design and the input signal goes to a channel select port of a 2in multiplexer. Could this cause the undetection of the signal state change?
During debug, I've seen that the output of the filtering instance is stuck @ 0V even if the input signal stay @ 3.3V for several minutes.
I hope I was more clear in the explanation, any further help will be so much appreciated.
thanks all
