19 years agoHippi Chik,
THis is a frustration for me as well. When using ALT_LVDS you need to use the following equation. RSKM = UI - TCCS - SW - tEXT UI = Unit Interval TCCS = Channel-to-channel skew SW = sampling window tEXT = Trace mismatch TCCS and SW are numbers that Altera provides in their data sheet. You can not use Tsu and Th numbers when using ALT_LVDS receiver. The ALT_LVDS receiver uses special circuitry to balance the sampling window in the middle of data. When you configure the ALT_LVDS block you are configuring a lot of hidden "stuff" in the block that ensures that the SW is within the published spec. SW has been characterized across PVT and is a 'guaranteed' number. You can think of SW as a balanced Tsu and Th number. Remember that these equations apply to the whole interface, but they can be used on a bit by bit basis. This is a complicated issue so if I didn't answer the question let me know. I have spent a lot of time with Altera applications on this question because it is very confusing. This only deals with the ALT_LVDS receiver. If you are in a mixed system with other devices the answer can be a little different. THis is all documented in teh various device handbooks under "High-Speed Interfaces".
