15 years agoTimeQuest User Guide
I've tried to answer a number of TimeQuest questions here, and as part of that, put together a TimeQuest User Guide. It's on the altera wiki site: http://alterawiki.com/wiki/timequest_user_gui...
15 years ago> Contact: ...if there is anything ambiguous, incorrect, or missing, please contact me via ...alteraforum..., sending an email to user Rysc.
Note forum restriction preventing this: "To be able to send e-mails to other users your post count must be 10 or greater." Therefore I will post this way regarding the Report Datasheet section; note [insertions] and /d/e/l/e/t/i/o/n/s/ below: * "values like Tsu, Th and Tco make sense in many I/O cases, but there are a number of situations where they can’t do complete analysis(such as source-synchronous interfaces)". What analysis is available vs missing for souce-synchronous interfaces... specifically, does it report Tco from active edge of clock output to data output? If so, how from the report's Rise and Fall columns? * Clock inversion, "So if two signals['] output ports were clocked on opposite edges of the clock, their data would come out at very different times, but their Clock to Output values would be the same. Luckily, the Datasheet has a column called Clock Edge. The following screenshot is from a design with an output bus called tx_[data]/o/u/t[7:0]..." * PLL Phase-shifts, "Let’s start with the same example as above, whereby a clock with a 20ns period clocks data out and it takes 7ns. Let’s say that it’s going through a PLL now, so the Clock to Output time is /s/t/i/l/l/ 4ns." Assuming 4ns is 7ns with PLL -3ns shift? * "If the user phase-shifts the clock +180 degrees [or]/o/f/ -180 degrees, the data will come out at the exact same time, but the +180 degree shift will give a Clock to Output time of 14ns and the -180 degree phase-shift will give a Clock to Output time of -6ns."
