11 years ago --- Quote Start --- //tristate flash bus signals when not in use assign flash_cle = (bus_tri_d) ? 1'bz : cle_d; assign flash_ale = (bus_tri_d) ? 1'bz : ale_d; assign flash_ce_n = (bus_tri_d) ? 1'bz : ce_n_d; assign flash_we_n = (bus_tri_d) ? 1'bz : we_n_d; assign flash_re_n = (bus_tri_d) ? 1'bz : re_n_d; Any guidance you can provide would be most appreciated C --- Quote End --- just curious why do you tristate output. I will only do that for bidirectional pin.
