13 years ago
Timequest: toggle synchronizer constraints?
Hi Ryan (Rysc) and anyone else with suggestions,
I have a TimeQuest question I was hoping you might be able to answer.
I have a toggle synchronizer that is used internal to a design. The toggle synchronizer uses the input to the synchronizer (a pulsed signal) to toggle a register. The toggle output is then synchronized to the output clock, and an edge-detector generates a pulse in the new clock domain. See sync_pulse_vhd.txt, sync_pulse.pdf, and the RTL netlist view sync_pulse.jpg.
TimeQuest correctly identifies the input signal as a clock, and generates the warning: "no clock feeds this register's clock port".
I have figured out how to get a collection containing the toggle register from within the project hierarchy (see timequest.jpg), i.e., the path to each toggle register t. However, now I'm stuck.
1) How do I identify the signal feeding the clock pin of this register so that I can apply a constraint to it.
2) What constraint should I use? Should I create a clock signal for each signal that feeds a synchronizer input, and then put it in an exclusive/asynchronous clock group, or should I just set a false path?
3) What is your advice on how to add this .SDC constraint to a project, eg., use an .SDC constraint embedded in the VHDL, or use a sync_pulse.sdc file that performs a loop over a collection, where the collection is based on the synchronizers used in any specific design?
Looking forward to your advice.
Cheers,
Dave
    You are not dense, Dave. Quartus is.
    After some googling... there's an issue with a setting called "Display entity name for node name".
    Put simply: they (default) way get_node_info works for register names is not compatible with the filters get_pins accept.
    http://www.altera.com/support/examples/timequest/exm-tq-entity-instance-names.html
    set regs [get_registers *sync_pulse:*|t]
    foreach_in_collection reg $regs {
    set regName [get_node_info -name $reg]
    puts $regName
    regsub -all {\w*:} $regName {} regName
    puts $regName
    set clkPin [get_pins ${regName}|clk]
    # now you should be able to apply constraints based on $clkPin
    I wouldn't call it abuse Quartus. But I would just live with the warnings; or suppress them.
    I don't like adding stuff I shouldn't just to suppress dumb warnings.
    Hi rbugalho,
    --- Quote Start ---
    --- Quote End ---
    Thanks! I'd missed that page.
    --- Quote Start ---
    --- Quote End ---
    The objective was to suppress the warnings. I am simply using TimeQuest constraints to suppress them.
    I've attached the "Report Clocks" report for both method 1 (the first method I figured out) and method 2 (the method you pointed me to on the Altera site). Because method 2 strips the component names, the clock name in the "Targets" field of the report window becomes less verbose, but then that means the hierarchy to the synchronizer is a little less obvious. I don't see any particular advantage in one method over the other.
    As I commented earlier, I plan to replace this synchronizer with one that uses the JTAG and core clocks directly, and I won't introduce this extra synchronizer clock, so I won't be using these TimeQuest constraints any time soon. However, this was an interesting exercise in TimeQuest syntax :)
    Thanks!
    Cheers,
    Dave
    I think your first method is creating the clock at the source of the signal, while the second is creating it at the sink (the |clk pin).
    I'd go with the first one.
    --- Quote Start ---
    --- Quote End ---
    Ok, that makes sense.
    --- Quote Start ---
    --- Quote End ---
    I'll check it into CVS with method set to 1 then :)
    Cheers,
    Dave
    As a late follow-up. I played around with embedding SDC statements in HDL and found two solutions.
    1. A simplified variant, assigning all toggle inputs to a single clock constraint
    attribute altera_attribute : string;
    attribute altera_attribute of rtl : architecture is
      "-name SDC_STATEMENT ""set_false_path -from "";" &
      "-name SDC_STATEMENT ""create_clock -period 10 ] -name ce_sync""";
    2. Embedding the complete SDC loop construct enumerating the clocks in a single SDC_STATEMENT line
      "-name SDC_STATEMENT ""set regs ;" &
      "set n 0;foreach_in_collection reg $regs {;" &
      "set clk ];" &
      "create_clock -period 10 -name ce_sync_input${n} ;" &
      "set_clock_groups -exclusive -group ;incr n;}""";
    Illustrating somehow Rysc's comment about the clunky way of embedding Timequest statements, but working though.
    A possible drawback of embedded clock constraints, they are executed before the regular SDC files and may block other create_clock statements to a node.
    Best wishes,
    Frank
    Hey Frank!
    Thanks for posting your embedded SDC constraints examples. I'll take a look.
    --- Quote Start ---
    --- Quote End ---
    Yeah, that is a valid concern.
    Thanks!
    Cheers,
    Dave
