14 years agoTimequest: toggle synchronizer constraints?
Hi Ryan (Rysc) and anyone else with suggestions, I have a TimeQuest question I was hoping you might be able to answer. I have a toggle synchronizer that is used internal to a design. The t...
14 years ago --- Quote Start --- I think your first method is creating the clock at the source of the signal, while the second is creating it at the sink (the |clk pin). --- Quote End --- Ok, that makes sense. --- Quote Start --- I'd go with the first one. --- Quote End --- I'll check it into CVS with method set to 1 then :) Cheers, Dave
