14 years agoTimequest: toggle synchronizer constraints?
Hi Ryan (Rysc) and anyone else with suggestions, I have a TimeQuest question I was hoping you might be able to answer. I have a toggle synchronizer that is used internal to a design. The t...
14 years agoHi rbugalho,
--- Quote Start --- After some googling... there's an issue with a setting called "Display entity name for node name". Put simply: they (default) way get_node_info works for register names is not compatible with the filters get_pins accept. http://www.altera.com/support/examples/timequest/exm-tq-entity-instance-names.html --- Quote End --- Thanks! I'd missed that page. --- Quote Start --- But I would just live with the warnings; or suppress them. I don't like adding stuff I shouldn't just to suppress dumb warnings. --- Quote End --- The objective was to suppress the warnings. I am simply using TimeQuest constraints to suppress them. I've attached the "Report Clocks" report for both method 1 (the first method I figured out) and method 2 (the method you pointed me to on the Altera site). Because method 2 strips the component names, the clock name in the "Targets" field of the report window becomes less verbose, but then that means the hierarchy to the synchronizer is a little less obvious. I don't see any particular advantage in one method over the other. As I commented earlier, I plan to replace this synchronizer with one that uses the JTAG and core clocks directly, and I won't introduce this extra synchronizer clock, so I won't be using these TimeQuest constraints any time soon. However, this was an interesting exercise in TimeQuest syntax :) Thanks! Cheers, Dave
