12 years agoHi Martin,
--- Quote Start --- It seems that I am trying to do something uncommon and that it is standard practice to just cut all paths across clock domains where signals are not expected to cross. Perhaps I should do the same. --- Quote End --- Its not unusual to find that you are doing something uncommon ... it happens to me all the time :) In this case, I would typically define clock groups with the asynchronous clocks in different groups, so that TimeQuest cuts all the paths. If a design is nicely implemented, with synchronous logic in their own blocks, and blocks connected via bridges/synchronizing logic, then I feel safe using this TimeQuest feature. If however you're trying to constrain a design written in the "spaghetti style" of coding, with numerous clocks, then I suspect you'll have other issues than just TimeQuest constraints, and a thorough review of that design would be advised before trying to setup timing constraints. Cheers, Dave
