12 years ago
TimeQuest Timing constraint and SDC file
I would like to compare two different designs with respect to timing. I do not have any experience working with SDC files. I've gone through online training available at Altera website but I am still not sure if I have done it correctly. I am only concerned about the timing from the input to output pins within the FPGA and I will ignore any delay from outside.
My first design is some inputs that fed into a combinational circuit and the output of this circuit is fed into a register and then the output of the register is fed into another combinational circuit that produces the output. Here is the SDC file I have created:
create_clock -period 10 -name clock [get_ports {clock}]
derive_clock_uncertainty
# virtual clocks
create_clock -period 5 -name clock_in
create_clock -period 5 -name clock_out
set_input_delay -clock { clock_in } -min 0 [get_ports {all input pins}]
set_input_delay -clock { clock_in } -max 0 [get_ports {all input pins}]
set_output_delay -clock { clock_out } -min 0 [get_ports {all output pins}]
set_output_delay -clock { clock_out } -max 0 [get_ports {all output pins}]
I've got negative time when I started the time quest analyser I am not sure what causes those negative time values!
The second design is some inputs that fed into a combinational circuit and the output of this circuit is fed into a ROM and the output is fe into a combinational circuit that generates the output. I did not write any SDC commands yet. I hope someone help me and check the previous SDC file.
I really appreciate any help :)
    Look at the Data Arrival Path of your first path. 8ns iExt is just the value you put into your set_input_delay -max.
    The 0.959ns and 2.642ns are input and output cell delays and won't really change. (You could increase your drive strength maybe)
    You go through two LUTs of logic, which is fast. The thing that is variable and hurting you are the two IC(interconnect) delays of 1.631ns and 2.874ns. Note that your input is at X47_Y51 and your output is X95_Y11. So you're going 48 LABs in the X direction and 40 in the Y direction, so that's a pretty long hop. Changing your pinout may help.
    You have only one set of registers(inputs => logic => registers => logic => outputs. Thus you cannot use dedicated io registers for either inputs or outputs. Since output is failing in your test then try them for outputs after adding another set of registers.
