TimeQuest strange behavior - seems like a bug in PLL output clock visualization
Hi IDeyn,
The clock you're looking at, divclk, is not directly derived from refclk. Vcoph[0] first derived from refclk. The rise and fall times for vcoph[0] have to be between 1.667 and the period of 3.333, which is why we see the drop in rise time at any refclk offset greater than 3.333. divclk inherits its rise and fall times from vcoph[0], not refclk.
If you want to force divclk to mirror the offset you add to refclk, you can overwrite its waveform with the -offset option as follows:
create_generated_clock -name {ip1_inst|altera_pll_i|general[0].gpll~PLL_OUTPUT_COUNTER|divclk} -source {ip1_inst|altera_pll_i|general[0].gpll~PLL_OUTPUT_COUNTER|vco0ph[0]} -divide_by XX -multiply_by YY -duty_cycle 50.00 -offset X.XXX { ip1_inst|altera_pll_i|general[0].gpll~PLL_OUTPUT_COUNTER|divclk }
Hi YY,
I've just tried create_generated_clock command.
I wrote commands WITHOUT -offset option and achieved proper results using Report Clocks command.
Here are exact commands:
create_generated_clock -name {pll1|secpll_inst|altera_pll_i|general[0].gpll~PLL_OUTPUT_COUNTER|divclk} -source {pll1|secpll_inst|altera_pll_i|general[0].gpll~FRACTIONAL_PLL|vcoph[0]} -divide_by 1 -multiply_by 2 -duty_cycle 50.00 -offset 0.000 {pll1|secpll_inst|altera_pll_i|general[0].gpll~PLL_OUTPUT_COUNTER|divclk}
create_generated_clock -name {pll2|secpll_inst|altera_pll_i|general[0].gpll~PLL_OUTPUT_COUNTER|divclk} -source {pll2|secpll_inst|altera_pll_i|general[0].gpll~FRACTIONAL_PLL|vcoph[0]} -divide_by 1 -multiply_by 2 -duty_cycle 50.00 -offset 0.000 {pll2|secpll_inst|altera_pll_i|general[0].gpll~PLL_OUTPUT_COUNTER|divclk}
I attached figure showing that results are right, as expected.
So, the conclusion for me right now is that create_generated_clocks works better than derive_pll_clocks. And it is a potential mislead.
Ivan
