14 years agoHey Ryan,
This is likely the longest question you've had to read (see the attached document). The document and code contains two designs; a synchronous design and an asynchronous SRAM design. Both designs are analyzed for timing, with some interesting results regarding the VREF pins. What is still not clear to me, is how to write the 'final' SDC constraints for the SRAM interface. Perhaps you could clarify that for me, and then I'll update the document, and you can add it and the code to your wiki entry. Cheers, Dave
