jesseopdenbrouw
9 months agoTimeQuest Question Relating PLL
I have a design on a DE23-lite board. I use the onboard 50 MHz clock to feed a PLL set to 150 MHz. All registers clock on the PLL. I_clk is the 50 MHz clock. I use the following rule: create_genera...
sstrell
9 months agoThis is Agilex 3 so just delete this constraint. PLL constraints are derived automatically based on your PLL configuration.
- jesseopdenbrouw9 months ago
Thank you for your answer. But now TimeQuest complains that the input clock has a negative setup slack, even if no flip-flop is clocked on this clock. How do I prevent that?
I_clk -6.440 -150.246 30
Greets
Jesse
