14 years agoOption b) works, but it does need a big red warning.
If you useset_false_path -from -to then, it just sets cut the path between the pins from analysis and just stops TimeQuest from complaining about unconstrained paths. But if you use set_false_path -from -to then it cuts all paths between those two clocks from analysis. Totally not what you want.
