14 years agoNote that your clock and data will be going out very close to each other. With default analysis, this is close to a hold violation. Quite often users will invert the clock going off chip. If you do this, be sure to add -invert to the generated clock. With rbugalho's example, the default setup relationship is 10ns and hold is 0ns. If you invert the clock, then the setup relationship becomes 5ns and hold becomes -5ns.
