14 years agoMeanwhile I added the lines below
set pci_inputs {PCI_LHOLD PCI_LINTO_N PCI_LSERR_N PCI_LW_R PCI_LBE_N* PCI_LA* PCI_LAD* PCI_DPARITY*} set_input_delay -clock { PCI_CLK_FPGA } -min -2.2 $pci_inputs set_input_delay -clock { PCI_CLK_FPGA } -max 7.5 $pci_inputs but I get the warning Warning: Assignment set_input_delay is accepted but has some problems at Camtest.sdc(125): Set_input_delay/set_output_delay has replaced one or more delays on port "PCI_LA[2]". Please use -add_delay option. I get this warnig for each signal. Any idea?
