9 years agoTimeQuest found "Unconstrained Paths"
Hello, Before approach "timing analysis" I've studied the ryan scoville's "TimeQuest User Guide", that can be found here: http://alterawiki.com/wiki/timequest_user_guide In the sectio...
9 years agoFinally it works ... in sense that there is no more unconstrained paths.
Well, TimeQuest reports timing violations, but this is another story. Here below - modified .sdc. If I properly understood your last message, you agree that for my case virtual clock is irrelevant ? create_clock -name clk -period 20 [get_ports clk] create_clock -name {altera_reserved_tck} -period 40 {altera_reserved_tck} derive_pll_clocks derive_clock_uncertainty set_input_delay -clock altera_reserved_tck -clock_fall 3 [get_ports altera_reserved_tdi] set_input_delay -clock altera_reserved_tck -clock_fall 3 [get_ports altera_reserved_tms] set_output_delay -clock altera_reserved_tck 3 [get_ports altera_reserved_tdo] create_generated_clock -name clk_ext_sdram -source [get_pins {u0|pll|altera_pll_i|general[1].gpll~PLL_OUTPUT_COUNTER|divclk}] [get_ports {sdram_clk}] set_false_path -to [get_ports {sdram_clk}] # Constraint SDRAM DATA for input set_input_delay -clock clk_ext_sdram -max 0 [get_ports sdram_dq[*]] set_input_delay -clock clk_ext_sdram -min 0 [get_ports sdram_dq[*]] # Constraint SDRAM DATA for output set_output_delay -clock clk_ext_sdram -max 0 [get_ports sdram_dq[*]] set_output_delay -clock clk_ext_sdram -min 0 [get_ports sdram_dq[*]] # Constraint DRAM ADDRESS for output set_output_delay -clock clk_ext_sdram -max 0 [get_ports sdram_addr[*]] set_output_delay -clock clk_ext_sdram -min 0 [get_ports sdram_addr[*]] # Constraint SDRAM Controlss for output set_output_delay -clock clk_ext_sdram -max 0 [get_ports {sdram_bank[*] sdram_dqm* sdram_cas_n sdram_ras_n sdram_cke sdram_cs_n sdram_we_n}] set_output_delay -clock clk_ext_sdram -min 0 [get_ports {sdram_bank[*] sdram_dqm* sdram_cas_n sdram_ras_n sdram_cke sdram_cs_n sdram_we_n}] set_false_path -from [get_ports sw*] set_false_path -from [get_ports key*] set_false_path -from * -to [get_ports led*] set_false_path -from * -to [get_ports hex*]
