9 years agoTimeQuest found "Unconstrained Paths"
Hello, Before approach "timing analysis" I've studied the ryan scoville's "TimeQuest User Guide", that can be found here: http://alterawiki.com/wiki/timequest_user_guide In the sectio...
9 years agoHi,
create generated clock for clock output pin which goes to SDRAM chip and constrain output pins to clk_extcreate_generated_clock -name clk_ext -source
set_false_path -to Create virtual clock and constrain input ports to virtual clock clk_ext_virt create_clock -name clk_ext_virt -period
