--- Quote Start ---
Did you run Report Minimum Pulse Width? I believe that is where your Restricted Fmax is determined. It's not part of setup/hold/rec/rem analysis. There should be something in your default timing reports that is red and shows failing, which I believe will be the Report Minimum Pulse Width. (It's not the best at clearly explaining why something failed, but usually gives enough detail to figure out the block and then you can find it in the data sheet.) But I am certain there is nothing Report Fmax does that isn't done elsewhere, and there's really no need to have it except some users like it.
--- Quote End ---
No it wasn't pulse width but hold restriction on fmax yet the hold slack was all positive. It must be tool responsibility not to pass hold slack in such cases but looks like it defines hold slack in the classic sense.
I would rather look at slack as well as restricted fmax for final verdict.
