12 years agoTimeQuest doesn't recognize generated clocks anymore
I have a weird behaviour of my TimeQuest since I have done a compilation with the Design Space Explorer (DSE): Since then, when I generate a new .sdc-File for my project and derive the generated clocks, it always uses the values before the DSE-Compilation. If I change some parameters (phase) in my PLLs, they aren't recognized anymore. I have to set them by editor in the generated .sdc-File. Another result of this is that Quartus tells me on compilation: Warning (332056): PLL cross checking found inconsistent PLL clock settings: Warning (332056): Clock: XXX_PLL_1|altpll_component|auto_generated|pll1|clk[1] was found on node: XXX_PLL_1|altpll_component|auto_generated|pll1|clk[1] with settings that do not match the following PLL specifications: Warning (332056): -phase (expected: 135.00, found: 45.00) Is this setting locked somewhere? How can I unlock this?
