Thanks for your interest so far :).
The main reset signal is called system_reset. I hope the PDF is useful. I doubt you will find anything but here it is ;).
Unfortunately i cannot use Signaltap because the board has no jtag connection.
Below are the constraints.
# # Generated SDC file "cre_mini_fpga.out.sdc"
# # Copyright (C) 1991-2009 Altera Corporation# # Your use of Altera Corporation's design tools, logic functions # # and other software and tools, and its AMPP partner logic # # functions, and any output files from any of the foregoing # # (including device programming or simulation files), and any # # associated documentation or information are expressly subject # # to the terms and conditions of the Altera Program License # # Subscription Agreement, Altera MegaCore Function License # # Agreement, or other applicable license agreement, including, # # without limitation, that your use is for the sole purpose of # # programming logic devices manufactured by Altera and sold by # # Altera or its authorized distributors. Please refer to the # # applicable agreement for further details.
# # VENDOR "Altera"# # PROGRAM "Quartus II"# # VERSION "Version 9.0 Build 235 06/17/2009 Service Pack 2 SJ Web Edition"
# # DATE "Thu Jan 07 12:24:25 2010"
# ## # DEVICE "EP2C20Q240C8"# #
# **************************************************************# Time Information# **************************************************************
set_time_format -unit ns -decimal_places 3
# **************************************************************# Create Clock# **************************************************************
create_clock -name {clock} -period 20.000 -waveform { 0.000 10.000 }
# **************************************************************# Create Generated Clock# **************************************************************
create_generated_clock -name {clk_50M} -source -master_clock {clock}
create_generated_clock -name {clk_25M} -source -divide_by 2 -master_clock {clock} }]
create_generated_clock -name {clk_12M5} -source -divide_by 4 -master_clock {clock} }]
create_generated_clock -name {clk_6M25} -source -divide_by 8 -master_clock {clock} }]
create_generated_clock -name {clk_1M56} -source -divide_by 32 -master_clock {clock} }]
create_generated_clock -name {clk_781k25} -source -divide_by 64 -master_clock {clock} }]
# **************************************************************# Set Clock Latency# **************************************************************
# **************************************************************# Set Clock Uncertainty# **************************************************************
# **************************************************************# Set Input Delay# **************************************************************
set_input_delay -add_delay -clock 10.000 }]
# **************************************************************# Set Output Delay# **************************************************************
set_output_delay -add_delay -clock 8.000 }]
set_output_delay -add_delay -clock 10.000
set_output_delay -add_delay -clock 10.000 }]
# **************************************************************# Set Clock Groups# **************************************************************
set_clock_groups -exclusive -group
# **************************************************************# Set False Path# **************************************************************
# **************************************************************# Set Multicycle Path# **************************************************************
# **************************************************************# Set Maximum Delay# **************************************************************
# **************************************************************# Set Minimum Delay# **************************************************************
# **************************************************************# Set Input Transition# **************************************************************
