14 years ago
TimeQuest and gate leve simulation incongruity
Hi guys!
I have a problem regarding a gate-level simulation. In order to isolate the problem I compiled and synthetised a design with a single FF.
I can't figure out whether it is due to wrong settings in Time Quest or in Modelsim.
I upload the project.
To summarise, I don't have any problem neither in compilation, nor in functional simulation, nor in Time Quest.
When I run the gate level simulation, I clearly see that the output doesn't follow the input after the latch edge but (sometimes) it does it after 1 clk cycle.
Has anybody an idea about the reason for that happens?
Thank you in advance,
Marco
    You could be looking at normal timing behaviour of lauch/latch. Compared to functional simulation the data transition will occur somewhere before next clock edge or even further in case of multicycle deconstraint.
    Thank you for your answer,
    my evidence is:
    1) the design is just a FF (no multicycle constraits). it has been simplified in order to isolate the problem)
    2) after compilation, TQ says that Fmax = 130 MHz (my design runs @ F = 125 MHz and non violations are detected by TQ)
    3) functional simulation (obviously) works perfectly
    then: expected behaviour:
    The output (q) is expected to follow the input (d) in a time within the launch edge and the latch edge
    but: observed behaviour (in gate-level sim)
    The output (q), sometimes (NOT always) follows the input (d) after the latch edge
    Thank you
