18 years ago --- Quote Start --- It just seems a little cumbersome to create a new netlist every time you want to perform timing analysis. --- Quote End --- You have to select a timing model when you create the timing netlist, but you can change the timing model with set_operating_conditions without deleting and recreating the timing netlist.
