16 years ago
TimeQuest Analyzer HELP!
Recently Im trying to use TimeQuest Timing Analyzer in order to the Fmax achievable by my design. Im using Quartus 7.2 sp 3. I have tried out the common tutorial file available from Altera website. But I dunno why I cant have the result I want. It appears that I have "No paths to report" in the reports.
From those tutorial sheet, it only mention how to Insert Constraint for Create Clock. Apart from that, I have nothing else for my SDC files. I believe that's the reason for having "No paths to report".
Its there any simple and straight forward help in writing SDC file? I only wanted to check the Fmax achievable by my design
Thank you very much
    t(pin-to-pin) is tPD which means the delay between two pins.it describes the time of input_pin ->combined logic->output_pin.
    the above is all i know about this,wish it's usefull for you.:)
    --- Quote Start ---
    --- Quote End ---
    thanks alot chenzhe =)
