1 Reply
Add
-file ".TQ/TQ_report.txt" That will write it out to a text file, so you can be sure it's being written correctly. If so(and I assume it is), then the window probably got pulled to the edge and isn't visible. Most likely you can pull it back. If you can't, I've heard deleting the following file works, which stores all the GUI sizing changes you made(everything will go back to default) C:\Users\<username>\quartus2.qreg or ~/.altera.quartus/quartus2.qreg
