16 years agoTimeQuest : Find unconstrained path
TimeQuest reports that there is an unconstrained path in its diagnostic report unconstrained Paths.
It says that there is 1 unconstrained input port and 1 unconstrtained input port path, but not under setup neither hold analysis is mentioned anything. none of the reports gives me a clue what input port this could be. has anybody an idea how i can determine what is missing, or how to find out what could be the source ? even more, this fpga is based on a platform where the same pcb is used with for different fpga projects. so the sdc files used are the same for all quartus projects based on this pcb. they only difference is that the fpga itself may change due to migration and the ips could be more or less depending on the project. unused pins, like ethernet if no mac is included are left unconnected if input or set to gnd or vcc if output t enshure safe funtionality. any comment greatly apriciated and welcome.
