16 years ago --- Quote Start --- i had already launshed the timequest and got these informations from the reports but unfortunately this report does not give any hint what is unconstranied. it does not tell any name, thats why i ssked for ... only numbers how many inputs ports and paths what i had already seen is that a verilog HDL block like always @ ( posedge clock or negedge nreset) could instroduce hard to find clocks as the negedge nreset could be clock so still i am seeking for an idea how to find the unknown input ... but thanks anyway --- Quote End --- Hi MSchmitt, after you have run the "Report Unconstraint Paths" you should get in the Report window your unconstraint paths with two folders. One for setup and one for hold Analysis. When you open the folder you get the requested info. Look to the attachment. Kind regards GPK
