Time-to-Digital Converter (TDC) implementation
Logic lock didn't help because Quartus thought it needed a larger area to locate the circuit. However, I somehow managed the implementation: instead of DFF primitives, I described the register using a process and manually deployed the elements in Chip Planner. After saving the placement and recompiling, the ALM configuration was as expected. The problem of implementing additional ALMs to set a fixed value of '1...1' on one of the inputs remained, but I can live with that.
As per the message posted before, there's no more concern or consideration on this thread right?
Sheng
Hi Sheng,
Overall the problem is solved. I am not fully satisfied with additional LUTs needed to set a constant value for one adder's input but this is of minor importance. Thank you!
