16 years agoTime Quest Warning
a warning is displayed when perform time quest analysis(post-map):
Warning: fs~reg0|fs could not be matched with a pin My constraint: create_generated_clock -name fs -source [get_ports {clk}] -divide_by 128 [get_pins fs~reg0|fs] FYI, I have a top module that connects the clock divider and square wave(using clock enable method): square_valid sq_valid1 ( .clk(clk), .reset(reset), .sq_ena(sq_ena), .clock_ena(fs), .factor(factor), .square_1(square), .sq_valid(sq_valid) ); mod128_counter mod128count1 ( .clk(clk), .reset(reset), .fs(fs), .two_fs(two_fs) ); Besides, i have tried: [get_pins fs] [get_registers fs~reg0|fs] //fs~reg0, the name get from RTL viewer [get_nets fs] All have the same warning. I have no idea what is the problem.. thanks
