15 years agoTime Quest SDC Command
I have an input clock that I want to bring through the FPGA and send directly to an output. I also want to constrain some data outputs against that clock. I am having difficulty getting TQ to accurately report the delay on that clock as it goes through the FPGA. I used create generate clock for the output and then setup out delay using the generated clock, but the clock delay is not present (no delay) in the data required path. Any help would be appreciated. Best regards, Robert
