17 years agoGenerated clocks are usually considered bad practice.
Why not try using a clock enable something like baud : process(clock) begin ... if (clock'event and clock = '1') then if (count = finalCount) then count <= 0; clockEnable <= '1'; else count <= count + 1; clockEnable <= '0'; end if; end if; end process baud; other_stuff : process(clock) begin ... if (clock'event and clock = '1') then if (clockEnable = '1') then do stuff end if; end if; end process other_stuff; Everything is driven from the one clock but the logic in the second process is controlled by a clock enable signal from the baud rate process. Hope this is of some help
