8 years agoThe result is right in emulator mode, but is wrong in FPGA
My code result is right in emulator mode, but when I compiled it and run in FPGA, the result is wrong. What reasons will cause the problem? And how to debug code in the situation? The code need...
8 years agoHRZ,
In response to your comment: --- Quote Start --- Yes, if you have multiple kernels running in parallel which read from or write to the same global memory buffer, and read/write order will affect your output, you will likely get incorrect results. Trying to synchronize such kernels using channels will NOT work. --- Quote End --- I have not explored this design pattern yet; but is this due to a lack of cache coherence (in the LSUs that are automatically inferred)? Did you ever bring this up with Altera or get a response?
