The quartus prime software quit unexpectedly(10M16SLY180)
Unexpected software error when I use LVDS constraints for pinsUnexpected software error when I use LVDS constraints for pins.The error message is as follows.Device Information:10M16SLY180 , The LVDS output pin information is J5.
Problem Details
Error:
Internal Error: Sub-system: FIOMGR, File: /quartus/fitter/fiomgr/fiomgr_io_manager_impl.cpp, Line: 18290
success
Stack Trace:
0x12db19: FIOMGR_IO_MANAGER_IMPL::get_tjnor + 0x389 (FITTER_FIOMGR)
0x12d63d: FIOMGR_IO_MANAGER_IMPL::get_tj_ssn_subtotal + 0x8d (FITTER_FIOMGR)
0x148556: FIOMGR_IO_MANAGER_IMPL::validate_lvds_tx + 0x7e6 (FITTER_FIOMGR)
0x11045c: FIOMGR_IO_MANAGER_IMPL::check_diff_io_physical_io_rules + 0xacc (FITTER_FIOMGR)
0x7d499: FIOMGR_IO::is_insertion_legal + 0xe59 (FITTER_FIOMGR)
0x133272: FIOMGR_IO_MANAGER_IMPL::is_insertion_legal_by_pad_id + 0xb2 (FITTER_FIOMGR)
0x9b18a: FIOMGR_IO_MANAGER::is_insertion_legal + 0x2ba (FITTER_FIOMGR)
0x98a2f: FIOMGR_IO_MANAGER::insert + 0xbf (FITTER_FIOMGR)
0x53760b: vpr_qi_place_io + 0xbb (fitter_vpr20kmain)
0x316e8c: l_aa_pl_positions_satisfy_io_constraints + 0x17c (fitter_vpr20kmain)
0x3143e4: l_aa_pl_move_is_legal + 0x1e4 (fitter_vpr20kmain)
0x3117fb: aa_pl_attempt_commit_move + 0x2b (fitter_vpr20kmain)
0x36d044: l_mpp_commit + 0x1b4 (fitter_vpr20kmain)
0x36f6eb: aa_mpp_perform_moves + 0x44b (fitter_vpr20kmain)
0x313410: l_aa_pl_perform_temperature + 0x220 (fitter_vpr20kmain)
0x3186bd: l_aa_pl_perform_anneal + 0xb9d (fitter_vpr20kmain)
0x311665: aa_pl_anneal + 0x95 (fitter_vpr20kmain)
0x307ea0: aa_pl_do_bulk_of_placement_phase + 0x650 (fitter_vpr20kmain)
0x307746: aa_try_place + 0x3a6 (fitter_vpr20kmain)
0x26ab11: aa_flow_do_placement_attempt + 0x21 (fitter_vpr20kmain)
0x26788b: aa_flow_place + 0x1db (fitter_vpr20kmain)
0x2673c4: aa_flow_fit + 0x64 (fitter_vpr20kmain)
0x55f8d8: VPR_QI_FACADE::vpr_qi_main + 0x68 (fitter_vpr20kmain)
0x38c84: fitapi_run_vpr + 0x84 (fitter_fitapi)
0x53158: FITCC_EXPERT::run_vpr + 0x138 (FITTER_FITCC)
0x52bed: FITCC_EXPERT::place_and_route + 0xfd (FITTER_FITCC)
0x51e3d: FITCC_EXPERT::invoke_fitter + 0x7bd (FITTER_FITCC)
0xb2c2: fcuda_execute + 0x1d2 (fitter_fcuda)
0xedbf: fmain_start + 0xa6f (FITTER_FMAIN)
0xb154: qfit_execute_fit + 0x454 (comp_qfit_legacy_flow)
0x1c4e: QFIT_FRAMEWORK::execute + 0x6fe (comp_qfit_legacy_flow)
0x19437: qfit_legacy_flow_run_legacy_fitter_flow + 0x2d7 (comp_qfit_legacy_flow)
0x14640: TclInvokeStringCommand + 0xf0 (tcl86)
0x16442: TclNRRunCallbacks + 0x62 (tcl86)
0x17c4d: TclEvalEx + 0x9ed (tcl86)
0xa6a8b: Tcl_FSEvalFileEx + 0x22b (tcl86)
0xa5136: Tcl_EvalFile + 0x36 (tcl86)
0x12435: qexe_evaluate_tcl_script + 0x4a5 (comp_qexe)
0x11393: qexe_do_tcl + 0x593 (comp_qexe)
0x176d6: qexe_run_tcl_option + 0x666 (comp_qexe)
0x37746: qcu_run_tcl_option + 0x1526 (comp_qcu)
0x16f1b: qexe_run + 0x39b (comp_qexe)
0x18012: qexe_standard_main + 0xb2 (comp_qexe)
0x1ea2: qfit2_main + 0x82 (quartus_fit)
0x12208: msg_main_thread + 0x18 (CCL_MSG)
0x13b18: msg_thread_wrapper + 0x78 (CCL_MSG)
0x15f13: mem_thread_wrapper + 0x73 (ccl_mem)
0x11a41: msg_exe_main + 0xa1 (CCL_MSG)
0x29bf: __scrt_common_main_seh + 0x10b (quartus_fit)
0x1257c: BaseThreadInitThunk + 0x1c (KERNEL32)
0x5aa47: RtlUserThreadStart + 0x27 (ntdll)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 23.1std.0
Build: 991
Edition: Standard Edition
- RichardT_altera
I could not find this internal error in our database. Could you help to share your design .qar file (Project> Achieve Project) that could duplicate this error? This will requires the engineering team to investigate on this.
For all cases with Fatal errors or Internal errors, we need to obtain a design test case to duplicate the error. Without error duplication on our side, finding a workaround or solution becomes difficult.
p/s: please keep in mind that any work involving our engineering team may take some time, ranging from a few days to a few weeks, depending on the complexity of the issue.
Richard Tan
- RichardT_altera
Any update on this?
Do you able to share the design .qar?
Richard Tan
- tiandada
I've added the project where I submitted the question, but I don't see it here. Please check.
- RichardT_altera
Are you referring to the tr.qar ? I believe I have see it attached in the system.
Richard Tan
- tiandada
Okay, if you can see it, there's no problem.
- RichardT_altera
I able to duplicate the issue and have submitted a case to the engineering team to investigate.
I will keep you updated as soon as there is any progress or findings.
p/s: Please keep in mind that any work involving our engineering team may take some time, ranging from a few days to a few weeks, depending on the complexity of the issue.
Richard Tan
- RichardT_altera
Just to inform you that the engineering team is still looking into this.
Richard Tan
- RichardT_altera
Quick check with you, may I know the urgency for this issue? what is the impact ?
is it intended to set LVDS to LVDS_Tx node?
Richard Tan
- tiandada
We need to make a prototype in May.I need LVDS_TX and I need LVDS_RX.
- RichardT_altera
Do you have a specific date when you need this issue to be fixed?
Regards,Richard Tan
- RichardT_altera
The engineering might take some time to investigate this as it is old devices.
Is it possible to change the device to 10M16SAU169I7G? As this device able to pass the fitter.
FYI, the device is SA as compared to SL.
SA : Single supply - analog and flash features with RSU option
SL : Single supply - flash features with RSU option
Richard Tan
