The Quartus Prime software quit unexpectedly
Problem Details
Error:
Internal Error: Sub-system: EMIF, File: /quartus/periph/emif/emif_gen6_emif_system.cpp, Line: 901
obuf_src_oterm
Stack Trace:
Quartus 0x79d50: EMIF_GEN6_EMIF_SYSTEM::add_dm_dq_requirements + 0x1240 (periph_emif)
Quartus 0x7783e: EMIF_GEN6_EMIF_SYSTEM::add_requirements_to_cells + 0x56e (periph_emif)
Quartus 0x74d1c: EMIF_GEN6_EMIF_SYSTEM::create_emif_cells + 0x34c (periph_emif)
Quartus 0x25cd6: EMIF_GEN6::create_design + 0x596 (periph_emif)
Quartus 0x17267: std::_Func_impl<<lambda_6a734b9f6e407e6c10ea1408a2172c70>,std::allocator<int>,bool,PCC_MODULE * __ptr64>::_Do_call + 0x27 (periph_pcc)
Quartus 0x118d0: PCC_ENV_IMPL::perform_op + 0x550 (periph_pcc)
Quartus 0x11c4c: PCC_ENV_IMPL::create_design + 0x20c (periph_pcc)
Quartus 0x1347e: PCC_ENV_IMPL::refresh_design_until_converged + 0x56e (periph_pcc)
Quartus 0xaa40b: PCC_PERIPH_FLOW::pre_plan_blueprint_flow + 0x36b (periph_pcc)
Quartus 0x13585: fit2_fit_plan + 0x2b5 (comp_fit2)
Quartus 0x16442: TclNRRunCallbacks + 0x62 (tcl86)
Quartus 0x17c4d: TclEvalEx + 0x9ed (tcl86)
Quartus 0xa6a8b: Tcl_FSEvalFileEx + 0x22b (tcl86)
Quartus 0xa5136: Tcl_EvalFile + 0x36 (tcl86)
Quartus 0x15246: qexe_evaluate_tcl_script + 0x4e6 (comp_qexe)
Quartus 0x1413b: qexe_do_tcl + 0x46b (comp_qexe)
Quartus 0x1a70e: qexe_run_tcl_option + 0x5ee (comp_qexe)
Quartus 0x146b1: QCU::DETAIL::intialise_qhd_and_run_qexe + 0xa1 (comp_qcu)
Quartus 0x1f8d2: qcu_run_tcl_option + 0x2f2 (comp_qcu)
Quartus 0x1a00b: qexe_run + 0x3eb (comp_qexe)
Quartus 0x1b14a: qexe_standard_main + 0x26a (comp_qexe)
Quartus 0x1fd2: qfit2_main + 0x82 (quartus_fit)
Quartus 0x167e8: msg_main_thread + 0x18 (CCL_MSG)
Quartus 0x17001: msg_thread_wrapper + 0x71 (CCL_MSG)
Quartus 0x21610: mem_thread_wrapper + 0x70 (ccl_mem)
Quartus 0x14b7d: msg_exe_main + 0x20d (CCL_MSG)
Quartus 0x2bc8: __scrt_common_main_seh + 0x11c (quartus_fit)
Quartus 0x17033: BaseThreadInitThunk + 0x13 (KERNEL32)
Quartus 0x4d0d0: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: qpro
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 20.3.0
Build: 158
Edition: Pro Edition
- BoonT_Intel
Hi Sir,
Seem like this is happening in the older version 18.0. Can you give it a try on the latest version? (19.1 onward).
- Sohail
I am using Quartus Prime Version 20.3 Build 158 09/24/2020. Is there another build since 9/24/2020 which I can use?
- BoonT_Intel
Hi Sir,
20.3 is the latest version. I am sorry, maybe I see wrongly that you are using 18.0 previously.
In this case, can you give a try to generate the example design, run compilation, and see if you getting the same error?
Otherwise, can you give me the steps to duplicate the error? or provide your design that behaves the error?
- Sohail
I am not sure what you mean by example design. Can you please give more details about this example design?
Is there a way to speed up communication between the two of us? Can we do a phone/chat/video call? It takes 24 hour to get an answer.
If I have to send you the design to you, what format do you want it? Please advise on speeding up communication.
- BoonT_Intel
Hi Sir,
I PM’ed you to ask for your contact so that I can contact you before I off starting today until the end of next week. But unable to get your reply. So, let me try to respond to you here.
The example design that I mentioned is the EMIF example design (ED). I am suspecting this because the IE (internal error) comes from the EMIF IP. So, I assume you have the EMIF (ddr4) ip in your design right? So, I am asking you to generate the emif ED and compile it to see if you also see the same error.
I tried the EMIF compilation at my side and I can’t see the IE.
So, I suspect the IE only happens in your design which maybe has some illegal connection. Thus, you can compare your design vs the ED. See if you export all the interface signals to the top-level (to external I/O). and also the local interface signal (amm_* -avalon-memory mapped signal) to the user logic (or any driver like nios processor).
Hench, please try with my suggestions as above. If the issue still persists, you can archive the design to .qar format (in quartus, go to project tab, archive project). Then zip the .qar file (because qar format is not allowed to attach in the forum). I will look into your design when I got the chance to online.
- BoonT_Intel
Hi Sir,
Is the issue still valid?
