12 years ago
The Problem when simulate the lpm_ff using ModelSim-Altera
I am a new learner for ModelSim, and I have met some problems about it.
I have made a simple dff using lpm_ff, the code is showed below
module fddf(clk,clear,q);
input clk,
clear;
output q;
lpm_ff f1(.enable(1'b1),.clock(clk),.sclr(1'b0),.data(clear),.q(q));
defparam f1.lpm_width=1,
f1.lpm_fftype = "dff";
endmoduleand I have write test bench for it, the code is showed below
`timescale 1 ps/ 1 ps
module fddf_vlg_tst();
// constants
// general purpose registers
reg eachvec;
// test vector input registers
reg clear;
reg clk;
// wires
wire q;
// assign statements (if any)
fddf i1 (
// port map - connection between master ports and signals/registers
.clear(clear),
.clk(clk),
.q(q)
initial
begin
// code that executes only once
// insert code here --> begin
clk=0;
clear=0;
// --> end
$display("running testbench");
end
always # 25 clk = ~clk ;
endmodule
But when I use ModelSim-Altera to simulate it, such error comes out:
error: (vsim-10000) c:/users/tei.ylib_tei-pc/desktop/dff3/fddf.v(10): unresolved defparam reference to 'lpm_width' in f1.lpm_width.
error: (vsim-10000) c:/users/tei.ylib_tei-pc/desktop/dff3/fddf.v(11): unresolved defparam reference to 'lpm_fftype' in f1.lpm_fftype.
The file I added to the ModelSim-Altera project is the design file and testbech file, also, the 220model.v and altera_mf.v, cycloneiii_atoms.v are included.
I am quiet confused about how to simulate the lpm parts, please help me , Thanks.
1 Reply
    I am sorry the problem solved. Use lpm_ff#(1) f1.(.....) can solve the problem.
