Altera_ForumHonored Contributor13 years agothe problem of timing constraint Hi: there are a lot of timing violations after synthesizing the SDRAM controller,the constrained clock is 150M. I noticed that the latch clock is about half period faster than the launch clock ,...Show More1.jpg88 KB
Altera_ForumHonored Contributor13 years agoThis problem has been solved after creating the virtual clock. Thank you !
Recent DiscussionsConnection bit order between hierarchyHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
