13 years agoThe info messages don't have enough detail. Run TimeQuest and do a report_timing -setup -detail full_path -npaths 2 -pairs_only -panel_name "2 worst paths" -file "worst_paths.txt"
Feel free to attach the text file. I doubt the source and destination are on the same clock. You're using a PLL(hence negative delays) and they always drive a global clock tree, so the skew would be minimal. Anyway, the TimeQuest report will help analyze it better.
