12 years agothe output is shifted by one clock VHDL
in simulation a code for QAM mapping used in OFDM .. the code is working great but i have a problem
the output is shifted by one clock the output that should appear in clk 1 with input11 appears in clk 2 with input 2 and so on the code is this is not clearly my code :) library IEEE; use IEEE.STD_LOGIC_1164.all; use IEEE.STD_LOGIC_ARITH.all; use IEEE.STD_LOGIC_UNSIGNED.all; entity qam is port ( clk : in std_logic; rst : in std_logic; input : in std_logic_vector(1 downto 0); Iout : out std_logic_vector(11 downto 0); Qout : out std_logic_vector(11 downto 0)); end qam; architecture qam of qam is begin process (clk, rst) constant mais1 : std_logic_vector(11 downto 0) := "001100000000"; constant menos1 : std_logic_vector(11 downto 0) := "110100000000"; begin if rst = '1' then Iout <= (others => '0'); Qout <= (others => '0'); elsif clk'event and clk = '1' then case input is when "00" => Iout <= mais1; Qout <= mais1; when "01" => Iout <= menos1; Qout <= mais1; when "10" => Iout <= mais1; Qout <= menos1; when others => Iout <= menos1; Qout <= menos1; end case; end if; end process; end qam;
