wenna
2 years agoThe increment operation (++) will cause an error.
Consider the following code. Using the i++ operation on line 17 causes an error. module test1 (
input wire clk,
input wire reset,
output reg [7:0] y
re...
KennyT_altera
2 years agoWe have quite a lot of loop example in the Quartus tools itself.
What you will need to do is open up a blank verilog files, right click and insert template. You will see the loop example that you want to do create.
Do let us know if you have further question? If no, we shall close this thread.
