16 years agoNo. Technically the hold time in the datasheet report should be the same thing as your requirement. If you want to loosen the constraint, then either make the value larger, or add a set_multicycle_path -hold assignment. (Although multicycles tend to imply synchronous transfers, which is not the case here.)
