12 years agoRun Quartus Analysis & Synthesis, Quartus will issue a warning if a signal is missing in the sensitivity list.
Or Use a good VHDL editor: e.g. the Sigasi VHDL editor will warn you, while you type your code. But even then run Analysis & Synthesis before simulating, it will find some other consistencies (which Modelsim eventually finds too)
