14 years ago --- Quote Start --- Which version of Modelsim are you using? Modelsim Altera Start Edition should know about the lpm library already, type vmap to see the library mappings. For example Modelsim 6.6c has the mapping: # "lpm" maps to directory C:\software\altera\11.0sp1\modelsim_ase\win32aloem/../altera/vhdl/220model. Perhaps you have managed to mess up your environment setting? If you are using a full-edition version of Modelsim, then you need to compile the library. I can help with that, if that is the case. Cheers, Dave --- Quote End --- sir i have installed Modelsim Altera Start Edition 10.0c and tried typing vmap it gives following error # Reading C:/altera/11.1/modelsim_ase/tcl/vsim/pref.tcl # Loading project voq_switch_2# ** Error: (vish-19) Failed to access library '220model' at "220model".# No such file or directory. (errno = ENOENT)# ** Error: (vish-19) Failed to access library '220model_ver' at "220model_ver".# No such file or directory. (errno = ENOENT)# ** Error: (vish-19) Failed to access library 'altera_lnsim_ver' at "altera_lnsim_ver".# No such file or directory. (errno = ENOENT) also tell me how to compile the library thank you sir
