14 years ago --- Quote Start --- it says lpm library is not found in modelsim.... what is the path for lpm library in modelsim and can i copy the same lpm library which is there in Quartus II to modelsim --- Quote End --- Which version of Modelsim are you using? Modelsim Altera Start Edition should know about the lpm library already, type vmap to see the library mappings. For example Modelsim 6.6c has the mapping: # "lpm" maps to directory C:\software\altera\11.0sp1\modelsim_ase\win32aloem/../altera/vhdl/220model. Perhaps you have managed to mess up your environment setting? If you are using a full-edition version of Modelsim, then you need to compile the library. I can help with that, if that is the case. Cheers, Dave
